I just bought a rotisserie restored 71 Charger and it came with a really loud howling ring and pinion. The entire rear axle assembly is all new parts and the ring gear has a Chrysler part number. The loudest howl is on coast down and it disappears somewhat when applying throttle to accelerate. We have the rear axle completely apart to see what happened and have some white lead coming to do a gear pattern check. When we were in the disassembly stage we noticed both axle bearing retaining plates were bent from something not being right inside when they tightened the axle flange nuts. The axle was assembled with ball bearing type axle bearings with non-adjustable axle bearing retainers. My question is: Should I retain these ball bearings or convert back to stock tapered roller bearing type with a RS adjuster? I feel like this probably isn't my problem with the rear axle gear noise, just noticed the departure from stock and would like to order the best parts for reassembly.
