Nacho-RT74
- 11:58 PM
- Oct 8, 2012
- Valencia, España
but in your setup, only the battery charging actually goes through the ammeter correct? I like that setup a lot, I'll probably end up gonig that route in my car actually.
Not in my setup, ALLWAYS is like that, the ammeter reads what comes and go from/to the batt. Whereas the batt keeps charged and your alt is able too feed all the car demands ( never being backing up by the batt ) AS FAR EVERYTHING is correctly sourced from alt side of the amm like factory made, your ammeter will never read any load. No load going throught, no heat!
Upgrade the alt and voilá! MaMopar made a big mistake using low capacity alts at iddle.
Then of course clean and tight contacts. And a reinforcement on some wires able to hold any other acc added.
