318 Poly Power Steering bolts through water jacket
Avenger
6:45 AM
Central Ohio
Just a quick one. My upper bolt on my power steering pump bracket goes through the timing cover. Im going to convert to manual steering. Does this bolt go into a water jacket and I will need to drain coolant or does it just go through the timing cover and i will be fine? Thanks in advance!
I just had the PS pump off of my Poly and lost no coolant. Not the end of the world if you do though so go for it.
Sweet. I think ill try to just go for it and if it starts dripping ill figure it out from there. Fingers crossed though!
