MCODECUDA
- 3:28 PM
- Jul 22, 2008
- Sherrills Ford, NC
It might not be that easy depending upon which size bearing that is on the input shaft. Maybe a spacer from Brewer’s is in order.Well, after checking some other things, we THINK we found the problem. The bearing retainer on the front of the trans is for a small block. I checked the casting numbers and confirmed, which means that it is about a 1/2" to small for the bellhousing. Going to order the correct bearing tomorrow. I would think that is throwing off the alignment. I know it was going to be some overlooked and stupid.
