Tony Tee
This blown out valley pan subject got me thinking.  Put a vacuum / pressure gauge under the dash to monitor the crankcase pressures or vacuum to keep tabs on the pcv system.  Or does this exist already?
			Throw a crank evac kit on it.This truck probably sees 40-50 hours of drive time a year (under 300 miles), so I'm asking for another 100-150 hours out of this powerplant before I pull it for a refresh/swap. Had the wrong carb gaskets so ill try to get a video of it idling today with the aforementioned blow-by. Have to do some light driving to get a trans log of some different shift scenarios anyways
That was real common back in the 70s on 440-6bbl engines, too much timing, bad gas, high compression and detonation caused exactly this, no holes in the pistons either....but when you pulled the pistons out the ring lands fell out in your hands. Ran nearly perfect otherwise, then boom crankcase explosion and the pan wrapped the intake.
While YOU might not think the blow by excessive, it obviously is.....& is bad enough to collapse the intake gasket. There is nothing else that can cause the gasket to blow OUT.
[[[[[[[The intake gaskets were well sealed when i pulled the valley pan off, the RTV that was on the front and back of the engine was still sealing]]]]]]] Where did all the oil come from then???
run your cover breathers to the exhaust system through that pcv away , that really pulls the crank cast and sets the rings down on the pistons , much like a vac pump .
I installed a 440 recently for a customer. He bought it used. The valley tray looked just like this one. It was bowed, but not split. Neither the customer or the guy he bought it from had noticed it. The motor had not been cleaned in any way. There was no evidence of any oil film next to the breather. I swapped the tray and put the engine in the car. It runs perfect. Has zero smoke on start or heavy acceleration. No oil mess out of the valve covers either. It was recently rebuilt before owner #1 bought it. Intake and exhaust ports appeared dry with no oil. Is it perfect shape? Probably not, but it runs fine. Why did it happen? Something pressurized it. When I worked at a Chevy dealer many years ago the used car porter was trying to start a SB Chevy pick up with eyther. It blew the valvecovers up at both sides of the intake. Ripped the metal around the inner bolts. I put new covers on it and changed the oil. ran fine.
Intake backfire on deceleration???? The throttle would be closed. Having an internal backfire does not seem possible. Post a picture of your current PCV and vent system? Is the valley pan pushed up again?Update on this:
Finally got the 8 speed shifting like i wanted, modern turning is a wild world. few numbers here and there make a world of difference. ANYWAYS why that's relevant is i finally got to do a few more WOT passes, and the cause of the leak revealed itself, i have an intake backfire on deceleration after the pull. AFR is 12.5 at WOT however, the PCV system is not what i thought and is basically allowing air back into the intake, creating a lean condition, hence the pop.
Which would also explain the controlled explosion of the valley pan with no signs of carnage. It did it again except this time i had the PCV system off the breathers and the puff came from the breathers not the valley pan (which fortunately sealed well)
I ordered the moroso evac kit to the headers, my neighbor has a similar set-up on his 63 nova running low 9s and its very clean.
Question on that:
Could one not run vacuum assist brakes T-d into the evac line? This would in theory provide the vacuum where i need it most at high rpm where the intake drops off due to the cam. Am i thinking right here?
What makes you think it was an intake backfire? An evac kit will not do anything to stop what you call an intake backfire. All that kit does is help evacuate crankcase pressures which I believe you have a lot of.From a WOT when I let off, that's when it happens. Not a controlled deceleration, essentially a throttle dump.
Valley Pan is fine, very nice piece from Hughes.
Ill get a picture tonight when I get back to the truck, with the engine cage and the shock reservoirs its hard to get clear pictures but ill try
