440 & Hemi oil pump difference?
TetanusShot
11:57 PM
Northeast Indiana
From a bit of reading online, it looks like the Hemi used the same oil pump as the 440, but with a stiffer pressure relief spring. Is this true?
I have a perfectly good low mileage 440 pump I want to use on my 484 Hemi.
The pump and relief spring are the same, 440 & Hemi. I have a 472 hemi and have 70psi when warm and about 1500 rpm.
Open it up and check the rotor for scoring and make sure you have .002" minimum face clearance.
