mn1017
New Member
65 Plymouth Satellite. Is it possible to use a newer electronic voltage regulator with the original alternator? Mine has only field wire terminal.
YES......PROVIDING it's the electronic voltage regulator replacement for the OEM mechanical voltage regulator. They are available on line from several sources for approximately $25-30 range. The electronic voltage regulator replacement resembles the origional and uses the same wire connections. Just remember to insure a good ground to the firewall mounting bolts. Disconnect the battery b4 doing any electrical work. The alternator will function fine.65 Plymouth Satellite. Is it possible to use a newer electronic voltage regulator with the original alternator? Mine has only field wire terminal.
