The Horvaths
If overfilled, they will puke. When cold, coolant should -typically- be up to top of the core itself.
So, if it is actually overheating, did you check ignition timing? As well, is it running well enough that an overly slack timing chain can be ruled out?
Now for the fun (NOT!): it may be possible that your exploded impeller left a piece or two that is blocking a passage. I hope that you pieced it back together to make sure that no big pieces were missing.
You might try to check for hot spots with a temp gauge.
