XX88MAN
Hi guys. Looking at a 68 Charger that seems to have a couple of issues. First the starter only works when boosted but that’s likely battery or loose connection. The big problem is when the starter does run, it doesn’t turn the engine at all. 440 and 727. The owner put a new starter on the car from a 90s Dakota. It doesn’t seem to engage the ring gear. Do these need a spacer or what could I be missing? Also the solenoid is not mounted solid due to a stripped out screw will that cause starting issues?
