Beep!Beep!
got a little bit more done ,one of the freeze plugs fell inside the block took way longer than it should have but magnet and the mechanical fingers got it then the oil pump shaft bushing was a pain tried getting under the collar but it busted. so I drilled it out to a thin thickness and split it, so it would drive out.New one in.
