71 Charger Superbee Tribute/Restomod Build
Worked some more on the tank. I was able to get the insert made and spent some time working on the interior baffle. After doing all that practicing I still screwed up that first corner of the insert, I was so pissed I wanted to crush it with a hammer... :mad: (yes I admit to anger issues). The second corner turned out way better and neither has any holes so I am going to call that a win.
View attachment 1430963View attachment 1430964View attachment 1430965
Will you have access to the top of the tank once it's installed, encase you have some issues?
Ive made some headway on the fuel tank mods
sorry noting to contribute, I'm just following now
very interesting
I was able to get the tank welded up finally, what a challenge that was. I still need to pressure test it but I am not real concerned about it.
Well today I installed the sending unit and pump and then mounted it into the car to see if the access panel is going to work (it will).
The guy I got the car from installed a take out trunk floor from another car and as you can see they just overlapped the old with the new, however I am probably going to try and fight my OCD and just leave it although I don't really like it.
I've been working on some transition pieces to go from the hard line to flexible lines, I have 2 points which I want to do this. I am going to put one in front of the tank and another one in the T bar crossmember. I am using 1/2" SS pipe and some SS -6AN weld on fittings.
Don't focus on the blue hose, I am just using this for mock up. The long ones are for the cross member whereas the 2 short ones will be for back by the tank.
I don't have much to report because life and a degree of procrastination have impeded my progress. I did get the tank end transition part done and mounted (after modifying it some because I didn't like the way it came out the first time.
I recently purchased a plasma table and have been doing some studying on Fusion 360 while I wait for all the parts to come in.
Also, I ordered a new stereo/entertainment unit for my 14 Ram 2500. The factory U connect (POS) died on the Nav side and since you cannot do car play with those I was looking at various methods to fix or replace the stock unit. There is a guy in FL that sells the newer Ram stereo that does have car play but this unit is like $2600, I chose to go with a Stinger Heigh10 unit which will give me Nav, car play, 4 cameras, etc. Now all I have to do is install it... lol
