727 differences between D and 1 from a stop
Tom in the Duster starts in second. Near 900 horse and a manual valve body (of course)
Ok this explains there is a mechanical difference/behavior between starting in D and 1, and answers my question. I think I will have to better understand automatic trans to really get it.
So the gear ratio is the same, but 1st allows for more slipping, which allows more RPM and more torque?
Is this typical of more automatics of the time?
I don't think you understand. 1st gear is provided when the forward clutch (rear location in the trans) is applied and the rear drum is held. In manual low the rear drum is held with the low roller clutch and the rear band. In the D selection the rear drum is held by the low roller clutch alone. Either way the components that hold the rear drum in 1st gear are both doing the same job. There is no difference in slip. The difference occurs on the 1/2 shift. To complete a 1/2 shift the intermediate band is applied stopping the high/reverse drum. The forward clutch is still applied. This creates 2nd gear. In the D selection when the intermediate band applies the rear drum is allowed to rotate as the low roller clutch only holds it in one direction only. In posistion 2, the rear band needs to release as the intermediate band applies. The low roller still overruns the same. So the only difference between the two selections is that the rear band has to release the drum if it's in selection 2. Either way the low low roller always hold the drum in one direction. So there is no "Slip" difference.
Doug - in a typical street deal, is the 1-2 shift cleaner/faster in “D” because there is only one action - applying the intermediate band, verses the two “simultaneous” actions of both applying and releasing the intermediate and rear bands?
I’m always amazed that I managed to do a complete rebuild my 727 successfully, but I continue to have the shallowest understanding of how the damn thing actually works. Good step by step instructions I guess.
Yes it is. Thats why many race valve bodies don't have low band apply. The 1/2 shift is seemless. It's either in 1st or in 2nd. There can't be any overlap like during the 2/3 shift.
I don’t remember, do you use LBA in your race car?
The racecar does not use LBA. I do have one in my street car as it doesn't have a shield.
To recap to the OPs original question:
The car will accelerate exactly the same in D-1st as it will in manual-1st, up to the shift point. Or, said differently, they will accelerate the same while in 1st gear.
A lot of other good info too.
Absolutely wrong! Kim
You know, at least when I try to correct some one I prove the point. looks like you need to study up Kim.
3) Misuse/abuse on the street or strip in first gear.
-Remember you can only damage the sprag in 1st gear. Start your burnout in 2nd, and shift to 3rd. When on the street, repetitively getting in and out of the throttle while in 1st gear can damage the sprag.
