KCbelvedere
What is the proper way to take the endplay measurement? I keep seeing conflicting things about letting the case support itself and pulling up on the output shaft and then some say to lay it on its side and pull on the output shaft.
I will say that I cannot seem to get any reading out of when it is vertical case supported. When it is on its side it is .15". That seems tight from what I have read but I am not sure I am even taking the reading correctly if it should be vertical.
Thoughts?
Thoughts?
