74 Charger Rallye 440 TX9
Brake booster, pedal assembly, HVAC cables/vacuum line, throttle cable, and other misc going on.
Bench bled the master cylinder and got the brake system all sealed up. Started on the HVAC box. Needs a couple minor repairs but overall pretty good shape.
Finished the HVAC box and got it installed. Had to modify an L bracket to secure the heater core and the Heat/Air flap had a section busted out. Used a fender washer rivited to the case to secure it and sealed the rest of the hole with AC wrap tape.
My work of art from Glen Ray showed up yesterday and today I got it installed. 28" with a 3 row max cool core. Had a solid inch in front of the fan clutch. I brought Bob a 947 core to Carlisle and when I told him my car came with a 953 he said he might have a 953 top tank and if so he would swap it out at no additional cost. He had one and swapped it out. Thanks Bob!
Glen-Ray does excellent work IMHO, and Bob goes out of his way to make sure it has the right part numbers and date codes. It's unfortunate that he's not taking in any more work.
He told me he is training the new owner so there is hope.
Got the dash all buttoned up. A-pillar and windshield moldings installed. Visors and rear view mirror as well.
Got the column finished up. Had to wait for the ignition switch to show up. Found a NORS Filko on ebay.
Jeff I think I will just drop of the charger for you to finish. Your flying threw it on your charger. Look great. :thumbsup:
We can slot you right in after the Road Runner is done. :thumbsup:
