'74 Charger SE Brougham Window Guide felts source.
Gold Rush
6:48 AM
San Angelo TX
I've had both door glass guide felts on back order for months from PUI , via another vendor. Can't proceed without them. Anyone have a source for these guides. At this point I'd even consider a reasonable condition used set Any help would sure be appreciated!!
What's a "window guide felt"?
If it's the part that screws to the edge of the inner and outer door window opening, a set for a similar model should work, since you don't need the rears.
Maybe I don't know the correct term for what I need. Have a 1974 Charger SE Brougham. Need the liner/guide/felt for the door glass guides.
The guide pads that are inside the door?
IDK about those, only the edge "sweeps".
Pic would help.
this is what people are calling "cat whiskers"-
