Any 68-70 Grill Restoration Tips..
dodge68charger
4:29 PM
Washington
I'm Gonna Attempt To Restore The Grill On My 68 Charger, I Was Gonna Send It Out But Thought Id Give it Try..
Any Tips, Tricks Or Methods I Should Use To Make The Process Go Easier. I Have A Few Grills And Will Make One Good One... I Hope Lol
Colours, Testing Vacuum Canister Method, Order Of Parts Install, Etc. Any Advice Helps.
Also Are The Vertical Lines Painted Silver on The Charger Grills? Thanks
Do you need to do any plastic repair? I just restored the grill in my '68 Charger and I ended up buying a piece of a busted up '68 grille on ebay and melting it in acetone to make a glue. I then used the glue to fix the cracked and busted areas on the grille.
