1 Wild R/T
Your 2.285 number isn't accurate.... I've been looking but haven't found the spec... I recall it being something like 11cc...
I got 9.609 cc.s . It's probably a little less than that, due to the slanted walls of the dish. I would probably use 9cc's in my calculator.69bee had that formula as ...im guessing ....a TLAR...(That Looks About Right) estimator...i guessing we can assume 10-15% error in it? Id like someone else to run those dish numbers...see how far off base this really is.
Dish is 2.88 diameter x .09 deep.
Either one...with the volume of the dish both are attainableI got 9.609 cc.s . It's probably a little less than that, due to the slanted walls of the dish. I would probably use 9cc's in my calculator.
Are you trying to calculate what you have now, or with the rpm heads?
Ive got a line on a set of used std bore hp pistons....or for 2x the price...the KB400 or kb167...if they fit with the closed chamber
What camshaft?
