Bearman First Straighten metal.
Do your plastic work.
Sand Plastic work
Prime 2x
Block sand with ridgid block 220
Prime again possibly 2 more times.
Block with 320
Guide coat
Block with 320 or 400
Spray body with Body wash, walk the car with Fluorescent light looking for any imperfections.
Spot any small stuff.
Sealer
Light block 600
Wipe down with Body wash
Apply three coats base
Apply 2 coats clear
wet sand 800
Wipe down with acetone
3 more coats clear
Sand Plastic work
Prime 2x
Block with 320
Guide coat
Sealer
Light block 600
Apply 2 coats clear
wet sand 800
3 more coats clear[/QUOTEo
Thank you so when I get done I should have some great looking arms also haha.
That is the absolute truth!And THAT is why paint jobs cost what they cost!
67 Coronet let me get this correct. First you prime
Second wetsand prime
Third you use a sealer
Forth wetsand sealer
And last of all you apply paint.
Don’t know how well the long flat ones would work on a 66-67 Charger or B-body. The painter that did our car said he does not ever want to another 66-67 b-body. Didn’t realize just how many angles, curves and body lines there are in the early Chargers. But he will do the later b-bodies.
You have to watch the psi recommended. The 7 psi you are seeing is at the cap, not at the gun. For my gun I need to run 30 PSIG at the gun to get 10 psi at the cap. I don't spray at that 30 psig I drop it to 26-28 and adjust from there. But, depending on your gun, you may need up to 40 psig at the gun to get 8-10 psi at the cap. I am always checking my gauge on the gun handle to make sure it hasn't drifted even with a push down lock feature. I also use a brand new moisture trap at the gun each time I spray color. I only use these once, and then relegate them to primer only use. Cheap insurance to prevent er a water droplet in your finish color coat.
