Botched Edelbrock 1407 rebuild?
Thanks!Vacuum about 11 from the small orifice on front of carb. 10deg per the book! Will try both vacuum and check. Too much rain here in PDX today. !
And is the fuel level ok? Can too high affect the fuel/air mix?
Too high=rich
Too low=lean.
D. Vizard claims that a 0.100" change in fuel level [ not float level ] is about one jet size.
I think you start a new thread, & give a FULL description of the engine/history of the problems etc. Then better able to help you.
Thanks,will recap in new thread. Today set timing 14 deg, perhaps idle a bit smoother, still backfires and quits. Note steam out rt side only. (no x pipe). Does that mean one bank rich or lean, and corresponding side of carb is mis-set?
If it is steam: suspect a crack or leaking head gasket that is letting coolant into the chamber. Would expect low coolant level in the rad. This scenario also ties in the symptoms.
I doubt that it is steam from condensation [which is normal ] because you would expect it from both exh pipes.
Thanks again for the idea of measuring the engine temps. As you can see from the data, #1 and #2 are comparable, but the rest of the left exhaust manifold is much cooler than the right, as is the temp on the L downpipe . EGT = exhaust gas temp. OAT = Outside Air temp. I took a video of the backfire every time I opened the throttle from idle, but cannot deduce how to include it. As you can see there is a large difference in exhaust condensation; much less on left. I am not sure how to interpret this. There is also an exhaust gasket leak, but I can't remember which side, and am too deaf to differentiate. Can anyone offer any logic here?
