- 1:52 PM
- Apr 13, 2012
- Granite Bay CA
I'm sorting out what I want to do with my 1970 Charger project. Some of what I'll be doing may be applied to my red car later. I like to look at this ratty Charger as a development vehicle even though the red car is a pretty well sorted car.
In terms of wheel alignment, I know that static negative camber helps in cornering because it allows the front outside tire to better remain perpendicular when the body leans while in a turn.
To gain negative camber, both alignment cams have to be turned in toward the engine.
AR Engineering sells these spacers that allow a 2 degree change in negative camber:
https://www.manciniracing.com/maracaspkit.html
They simply tilt the knuckle/spindle away at the bottom.
MY question is this:
Would this allow more negative camber AND caster since it would allow the front alignment cam to be adjusted all the way toward the fender?
I have no engine in this project car so I may be experimenting with a few things. Camber is easily visible, as is toe in or toe out. Caster is a bit harder to see except at full left or right.
These A R spacers look to be about 1/8" thick. Thinner washers would surely provide less negative camber.
I may experiment again with the Moog offset upper control arm bushings as well but these spacers are a cheap and interesting idea.
Anyone here had any experience with these?
