Changing engine from 360 to 440
SilverBack67
12:06 PM
Texas
Good evening my name is Erick and I have a 1967 Dodge Charger. The original engine was a 318 but someone swapped it for a 360 before I owned it. My question is if the 440 was an option on the car when it came out, would I just be able to swap a 440 into it? Or would I need to do other modifications to it. Thank you in advance for your help. This is my first project so I am learning as I go.
Most likely you have a 8.25 rear dif, if you just plan on cruising the car the rear dif will hold up, but any hard starts/burnouts it won't last long. A bigger radiator and shroud may be required to keep it cool. Torsion bars are different, but just for cruising, the ones you have should work for awhile. You may need a different driveshaft, the 727 trans is about 4 inches longer than the 904, if the car came with a 904, if it came with a 727 no worries.
Mark
Chargers didn't come with 8.25 rears so you should be good.
Find a 440 complete with trans and have at er
Mark
No 8 1/4 in 1967.
The car should have an 8 3/4, which will be fine.
