Spare Parts
How difficult is it to change the radiator support from 22 inch to 26 inch on a 67 Plymouth
That extra quart or 2 of coolant makes all the difference regardless of the hole size! Cr8crshr's 66-300 had a 22" radiator and he had cooling issues that we couldn't nail down. We raped an old Monaco at PnP of it's 26"er, the shroud and clutch fan and threw it into the 300, didn't even bother to cut out the hole, just drilled 2 holes and installed it, no more issues whatsoever. I would have to say that those 4 inches isn't affected with a 22" hole that's already there. This was BTW when we were in CA. so you know about the heat!I'd like a few of you to explain why a wider radiator would work just fine if 4 inches of the width is blocked by sheet metal. The entire point of using the bigger radiator is to improve cooling.
I do t always fully understand the reasons why the automakers build cars the way that they do but I di t recall ever seeing any car factory built with a radiator core wider than the support.
Figures… GM always cutting corners.I’ve got one. Diesel squarebody Suburbans (and 89-91 454s) have an extra wide radiator that extends 4-6” wider than the core support opening on the driver side. I swapped to that setup in my ‘86 when I did the 8.1L Vortec conversion. I’m sure there are many others that way.
Like I always say. "Nobody sweats the details like GM, and they don't"!Figures… GM always cutting corners.![]()
Yes, if you block the outer 2" on both sides you haven't improved itI'd like a few of you to explain why a wider radiator would work just fine if 4 inches of the width is blocked by sheet metal. The entire point of using the bigger radiator is to improve cooling.
