Mark Draheim
My install, a 2005 5.7 truck engine auto trans combo in a 63 Plymouth Belvedere, I purchased the wire harness from Chris at Hotwire Auto and they did the program/flash of my computer. I am using Lokars billet drive by wire throttle pedal with the adapter pigtail from Chris also. Have installed a push button for starting. when we fired it up the first time everything worked like a new car in that the accelerator pedal worked as it should.
Now after moving and trailering the car to another state the DBW will only rev the engine once on initial startup and then nothing. The battery has been disconected and reinstalled a couple of times. Per Chris I checked to see if the engine was turned of and restarted would the DBW function and it will, once, then no response again.
Chris has suggested an ETC relearn with a good ($$$$) scan tool.
I talked to Lokar tech support and they said I could send them my DBW throttle assembly and the would test it for me.
Another suggestion was the original throttle body may be bad.
Has anybody had similar issues in the past?
Does anybody here have any suggestions on how I should proceed?
Any help will be appreciated.
