Early B Body turn signal switch discussion. Shee Mar SM102
The only other way to do it on my Polara anyway, would be to separate the rear lamps and have one brake and the other a turn signal on each side. Bypass the brake light portion of the TS switch. Naw, I'll wait for Dan to get some switches in.
I think I'll talk to Jeff my buddy that sells used Mopar parts. May be he will have a good used switch (and some molding clips I need.
I feel bad about this whole thing. Finally found the time to change the switch. It went well. Thought the Shee-Mar was fine at first. Discovered the weird rear lights flash position. Shee-Mar was great on the phone but that didn't fix my switch. Tried Dan. He is out. Hard to find OEM switch. Almost ready to bypass the turn signal switch for brake lights and just use the trusty old hand signals. Or just drive on straight roads and never turn.
C body switch will work. See other in this thread.
OK I got REAL lucky and a guy in Canada accepted my offer for a OEM Mopar switch for 62-63 so I just had to change the terminals to the 64 style. Night and day difference in feel compared to the Shee-Mar switch and everything works perfectly. I will still want to order one of Dan's switches for a spare. I believe the Shee-Mar is a decent alternative if you want to make sure the brake lights work. I was able to finesse my Shee-Mar and make the signals work and avoid the strange flashy rear light thing but I didn't really like that.
I guess that's why you never responded to me after I took the time to dig out and take pics of my nos switch and the used one that you ASKED me for...
Well geez I am sorry. When I opened my PM folder I got a notification that it was full and I accidentally deleted everything to clear it out. I am trying to get this car ready for what will certainly be the last car show my brother will be able to attend and I am in a real rush. Sorry for the trouble.
I just started looking for a fresh switch for my 63 Fury, and interested in the NOS if still available?
I did post this in another thread but it bears repeating. Here is another option. I was able to buy a whole column from a friend with a solid feeling oem switch in it. It was a turd to get the terminals released (another story) but the switch came out fairly easy and cleaned up nice. I will still get one from @Slantsixdan if he has some available.
What is Shee-Mar, it the who is repopping them?
Is shee- mar the only ones making these?
No. Other companies make them. Unless the supplier tells you, the manufacturer isn't known. Same part numbers may be a clue.
