Engine bored 30 thousands over
70 sublime
1:28 PM
Port Hope , Ontario
Trying to figure out what the new cubic inch a 440 engine would be if it was 30 thousand over
Does 30 thousands mean they took that much off each side so the diameter is 60 thousand wider or does it mean they took 15 thousand off each side and the diameter is 30 thousand wider ?
Bore X bore X stroke X.785 X number of cylinders.
4.35 X 4.35 X 3.75 X .785 X 8 = 445.62487
Each individual 440 would have to be measured and calculated.. each bore had 4 different size ranges. Not to mention the factory .020 overs.. :eek:
so a .030 bore only removes .015 of metal?........ I never thought about it
Technically speaking, yes, from one side, but only if you are measuring radius which is from the center to the outside. Diameter is the measurement across the bore so if you remove .030 it's thirty thousands larger. Do yourself a favor and don't go down that road.
Don't spit out too much coffee.. its been proven effective to win EM competitions
Only to make thing's perfect where every last fraction of horsepower makes a difference in who wins.
