moparcleyon
when I turn the key on the gauges peg out... 1962 Plymouth Belvedere
Not to hijack the thread. Is there a way to test the voltage limiter for the gauges?
actually SPIDER, i was answering the original question.and if the gauges PEG TO FULL...theyre grounding out....plain and simple. SPIDER...your issue seems to be a floating ground someplace. but if you want to check the voltage limiter without ripping apart your dash, HERES HOW :Everything is original 1966 to the car, The headlight switch I installed was Nos, not purchased at Napa or such parts store.
Found an unwanted ground? The gauges are only effected when the headlight dash dimmer (rheostat) switch is turned to brightest setting with headlight switch pulled on. If I turn on the headlights and have the dash light turned bright all the way, then go a tad further to turn on the dome light (completed circuit to ground) then the problems go away.
I don't think it would or could be the voltage limiter.... The gauges Don't peg out, just go up about a 1/4 inch if my lights are on & ONLY if the dimmer (rheostat) dash light switch is turned up bright.
It Really looks to me like I am missing a ground...
Car was purchased from the original owner 10 years after he died. Sat for 10 years +. Had 80K original miles. Car was well kept (mechanically, not physically).
I will check the 2 spots for ground issues (headlight switch or tail light assy) Then post what I find. If that does nothing..... May be the voltage limiter.
