Grendel lives...resurrection of a 1970 Charger 500
Ahh, armrest bases...I have 2 or 3 sets, but why do they all look like this?
Since not all of us can afford expensive shiny plastic things to replace all the parts on our cars, I wanted to remove the chrome on these and paint them. I tried sanding off the chrome from one and what a righteous pain. I got about a third of the way done and gave up. There HAD to be a better way to de-chrome ABS plastic. I've easily removed chrome from nylon parts for RC cars with an acetone bath, but that won't work with ABS plastic, it'll melt the plastic.
I found a Youtube vid of some modeler who tried LA's Totally Awesome Cleaner to remove plating from plastic model parts, and since it's cheap as dirt--$20 CAD for a 64 oz (nearly 2 liters) jug, I thought I'd give it a try. I put a pair of small armrest bases in the bath for a few days--one day to do the tops, one to do the bottoms, so as not to waste too much of the cleaner. Lo and behold, nearly all of the chrome either was dissolved, or easily wiped away with my finger. What remained, I used some 0000 steel wool and it all came off.
Now the bases are ready for some SEM Trim Black for a satin finish.
Since chromed steel is a totally different process than ABS plastic, I didn't think the cleaner would harm the chrome, I thought I'd do a test and soak a "Custom" metal chrome emblem to see if it would remove all the crud and crusty, flaking-off black edge paint. A day later and the black paint was coming off with a fingernail. A soft brass bristle brush took care of the nooks & crannies. So, into the bath went my "Charger" sail panel emblems. 2 days later:
These turned out so nice, I don't even think I'll paint the black edges before I reinstall these. It seems a shame to hide that nice chrome. I know it's not original but less and less of Grendel is gonna be original, so no worries. I actually think the full chromed emblems will stand out even nicer on top of my black vinyl top.
Before painting with the SEM, spray some adhesion promoter[ available in spray cans at autobody supply shops] on the parts. This will ensure the paint actually bonds to the plastic. Its like the purple primer used on PVC pipe prior to putting the actual glue on.
I restored and reinstalled my nice gold Pentastar emblem. I degreased it and filled in the valleys with gloss black acrylic fine-tip paint pen. The next day, I sprayed 3 coats of Duplicolor Wheel Gloss Clearcoat to give it some protection before reinstalling it. I would've preferred to use Spraymax 2K Clear but I didn't want to crack open the seal for just this emblem, and I have no other items to clear at the moment, so the wheel gloss should be sufficient.
My car already had the mounting holes so installing it in the correct location was a no-brainer. I managed to track down the 3M Emblem Adhesive for $18, which is still ludicrously expensive for such a tiny tube, but at least it was better than the $50+ I was seeing almost everywhere.
I got my freshly cleaned sail panel emblems installed on the vinyl top with the 3M Emblem adhesive. To get them to fit flush, they needed a bit of gentle bending to match the curvature of the roof, and I used some strong hard drive magnets along with masking tape to keep them in place until fully cured. I then scrubbed the vinyl top clean with a soft bristle brush and 303 Aerospace Protectant.
Nothing ever goes easy with this car...
I was installing my front sidemarkers and for some reason, they absolutely would not fit flush when the retainers were bolted on from the inside. Even fully tightened, the front and rear corners were out a couple 16ths of an inch. Since the markers fit nice and flush without the retainers, I checked out my retainers. All of them were the same, but I tried others, with no change.
I read on here someone posting that '70 Coronet markers have the mounting studs slightly closer together. I compared the widths of my mounting studs on several housings and they were indeed SLIGHTLY closer, but maybe 1/16", not enough to make a difference. I then placed the 2 chrome markers I chose as the best pair that I already installed new lenses in, beside a retainer, and found something clearly more important than a slight difference in the spacing between the studs; the mounting studs on the best pair of markers were at least 3/16" below where they were located on my collection of used and damaged markers. This pic says it all:
Here are all my other housings & retainers:
Notice that one of my chosen pair in the first pic has studs below the big pigtail hole, but all my other crap markers have the studs above the pigtail holes.
So what I concluded is the best pair of markers that I chose to install my lenses in are actually Coronet markers, because they don't fit any of my retainers, and don't match my extra markers, 2 of which are my originals.
Here's how I resolved this...since I have the luxury of having 2 sets of retainers, simply drilling some new holes where I've indicated in red Sharpie marker in the first pic should hopefully let the sidemarkers and retainers bolt in snug & flush. That indeed did the trick...sidemarkers installed successfully, nice and tight.
So the big difference between Coronet and Charger sidemarker housings & retainers is the mounting studs and hole locations are below center for the Coronet, and above center for the Charger. You can make either work because either sidemarker housing will fit just fine in the fender, but the holes in the housings need to match or be drilled to match.
Having acquired a nice antenna bezel and tube nut over the past few months, I was finally able to install my antenna base and fill the gaping hole in the fender.
With the door open about 3/4, my 14-year-old daughter was able to sneak her arm in between the door and inside fender and position the antenna base up through the bezel enough so that I could begin threading on the tube nut. I found a needle-nose Vise-Grip pliers was perfect, the nose tips perfectly fit inside 2 of the notches and with it slightly tightened, I was able to easily twist-tighten the tube nut to the base with no risk of slipping. I probably wouldn't recommend doing this with an ordinary needle-nose pliers, though.
My daughter was also able to pull the antenna wire through its hole in the sheetmetal ahead of the door.
I made sure I had the orientation right so the antenna was straight when installed.
I managed to dig up and scan some photos of my Charger as it was when I bought it, original F8 green with green vinyl top and white interior. A bit of an odd combo. Rust holes in the fenders and quarters and chrome steel slots. I've never seen chrome steel front slots like these ones, they weren't simply recessed dishes like the rears, they had a raised ridge just outside the slot holes. Anybody have an idea who made those?
I had some help yesterday to put my rear bumper back on. I had to remove it to route the wires to the license plate and reverse lights properly, because it's impossible to do with the bumper installed. I also polished up a few spots on the right side between the finish panel and bumper that I accidentally scuffed up trying to line up all the mounting clips for the finish panel.
For the first time since I bought the car--when the hood signal lights weren't working and the passenger side one was totally missing--Grendel has her new winkers installed.
New wheel teaser: Grendel showing off her new heels. I'm still working on front brakes and offset UCA bushings, so nothing on the front yet...
Finally got the front valance reinstalled. Encountered a number of difficulties. Counting the holes on the mounting tabs, one tab on each side was missing 2 holes. My body man repaired some rusted-out mounting tabs but he didn't re-drill the holes, so I had to measure carefully and drill the holes. Fortunately I have a spare but more beat-up valance so it was easier to take measurements. Then, when I had 2 helpers to help me install it, I noticed the holes on the 2 outermost end mounting tabs didn't line up. Again comparing to the fender tab holes and the other valance, I saw that my body man didn't drill one of the holes on each tab in the correct spot. So, I had to drill 2 more holes.
I did a bunch more measurements and mostly satisfied with things lining up theoretically, I again enlisted the help from my wife and daughter to hold it in position while I got some of the bolts threaded in. I found the easiest way to get the front valance installed was to first position the center brace just to the right of the center rad support where the 2 mounting holes are, then get the 2 outermost bolts on the driver side of the valance started. I then got the outermost 2 bolts threaded in on the passenger side. It took some flexing of the fender, and flexing of a few curse words, but everything finally got lined up and bolted in. Reconnected the park lights and one more step closer to the exterior reassembly being finished.
When I was working on the driver's side rear fender splash shield, and while installing the valance, I was seeing light shining through a hole in the area of the engine bay near the battery, where the fender attaches to it. The sheetmetal there was bent out and installed crudely, I believe by the guys who did my slap 'n' dash body & paint back in the 80's. Some old black seam sealer was not working to fill that area, I'll call it the fender crease. That's where there was a noticeable space that I need to repair. I dug out the old seam sealer, which was disintegrating, to clean up the area and unbolt a few of the fender bolts so I can open up the crease and clean it, and do my best to straighten the sheetmetal so it'll lay more flat against the fender sheetmetal.
any advice on running these through the hood and through the firewall to hook on to the blinkers? can you wire them to the blinker switch without taking the wheel off or did you pull that too?
I didn't have to run them through the firewall because I already had the two connectors at the firewall for the blinker wires. I had to repair one that was way too dried out and brittle with some fresh wire, but other than that, I just had to run the wires across the rear of the engine bay and connect them to their individual connectors.
As for running the wires through the channels in the hood, my post #100 on page 5 discusses this. I used a 4-foot-long length of windshield washer tubing to route through the channels, and once I was able to tease the hose all the way through--you may have to reach in and snag it with your fingers--I taped the end of the indicator wire to the end of the windshield washer tube and pulled it through.
Update on the fender crease repair...a pic showing how it looked after I unbolted 3 of the fender bolts, after about a half hour of careful hammering to get the inner seam sheetmetal straightened out and more closely matching the outer fender seam:
The two sheetmetal halves didn't want to stay together, so I liberally applied J-B Weld black seam sealer/adhesive and here's my ghetto but functional method to "clamp" the 2 sides together: :lol:I cut various lengths of wood to the correct lengths to jam the inner seam to the outer:
I was concerned (and still am) if the seam sealer would form a strong enough bond to keep the 2 halves joined, so after 24 hours to cure, I bolted on the 3 fender bolts and removed the wood posts:
To my surprise, everything stayed put. Hopefully for the long term! There's a spot right at the front where there's still a tiny 2-inch-long gap, I'll need to buy more J-B Weld to fill that area. Then, rough it all up and give it a few coats of DOM16 rust paint for future protection.
