- 6:00 PM
- Jan 1, 2013
- Mascoutah, Illinois
I've got my R/T in the garage finally. It has not been fired up since about 2003 so 10 years. I'm thinking it would be wise to pull the heads and check out the cylinder walls since I've never had them off previously. It's an matching numbers engine that doesn't look like its ever been apart, and it hasn't been turned over for 10 years, there is no oil left on the cylinder walls etc. I did put a socket and breaker bar on the harmonic balancer bolt and it did move .. but I didn't want to push it and just moved it a little to see if it was locked up.
I'm thinking I should pull the heads take a look and see what I see. Then spray some WD 40 or PB blaster around the rings etc and let that work it's magic for day or two. If everything looks ok and it wants to move then pour some oil over each piston and let it work its way past the rings. '
Next step in my plan is to use the oil pump priming tool to pressure up the oil pump and rotate the assy with the crank bolt again through a whole cycle to get it lubed up good.
Followed by buttoning up the heads intake etc and put a carb on it and see if I can fire it up. (I plan to get a new fuel tank, pick up, and maybe fuel lines first. I'll also be draining oil and trans fluid/filter)
The carb is missing so I have to get one. I found a supposedly new 750 Edelbrock on CL for $135 and while searching for that I came across this set of heads.
I haven't checked my R/T heads but according to the casting number that's the same set of heads. I called the owner and he didn't have them done. He said he was told they had a "standard head job done". I don't know what that means for the set and he didn't either but I'm assuming it's not a 3 angle valve job and I have no idea what they did with the valve guides or seals or if the heads have been surfaced. There is some rust so this was a while ago. If they did the valve guides and seals this seems like a good purchase for me to freshen up the engine. I also have a set of 915 heads off of a 67 383 that have the small exhaust valve and a set of 906 heads. These heads as well as the ones on my 440 all are in need of a valve job and seals, guide work etc.
Recommendations on my plan above and/or the purchase of these heads? i would appreciate all comments and suggestions and if I'm missing something obvious please point it out.
