Thats a authorised box, not a real as I say Mopar box. Bet you bought a kit to put in.
How to tell a "fake" ECU from a real one
I am not sure if I believe the fuel gauge. Have you used the oil filled gauges are they accurate?0 Fuel pressure is typically not a good thing - And you having to crank it over for a little bit to refill the float bowls answers your question
I probably bought the box through Mancini racing.Thats a authorised box, not a real as I say Mopar box. Bet you bought a kit to put in.
What do you mean by ignition test.Where is your guage line at? If it is near the carb take the line off and use a fuel pressure guage on it, like a tester one or a known good "car" guage. Do the ignition test first easy and fast.
Ok I will try these suggestions thank youI would think that guage would be fine "hot" if you have a regulator adjust it while running. Ignition test just pull the coil wire off after it dies and crank it to see if you have a good hot spark.
You mentioned changing power valve but then you say it won't affect idle. I had a small off idle lean surge and a carb rebuilder recommend the 8.5 since my cruise vaccum was 14. I can try the a 4.5 I have one easy enough to do."I am running a 8.5 power valve. Idle in gear vacuum is 9 but car runs great until reaches about 190-200 Cruise vacuum is about 14. Should I go to a 6.5 power valve.
Choke is open all the way."
"So let me expand on my early post. When it is warmed/hot it spikes lean at idle on my air fuel meter then I can give it more fuel and it goes rich. It runs irratic unless I keep the throttle at say 1300 or more rpm."
Typically your power valve shouldn’t effect your idle - Unless it is leaking or ruptured
It goes rich because your power valve is opening
What else have you done with that carb ? Sounds like an idle circuit issue
First off you need to change to a 4.5 power valve like I mentioned earlier
Anyone you recommend?Talk with the Holley experts over in the fuel section of this website
Start there
Peace
You eliminated fuel pressure
You pretty much eliminated ignition
So
