- 4:17 AM
- Apr 13, 2012
- Granite Bay CA
Thanks for the kind words.
The underhood portion is almost done. If I were out there actually working each day, this would have been done a lot faster. Phone calls, favors for people, yard work, side jobs, buying that other Charger, lazy days...They all got in the way.
The belts are on. Fan and fan shroud are in. The new drier is in, all the lines are secured and the wiring to the compressor are in place and ready. The system needs to be evacuated via the vacuum test, then I can fill it. The instructions show to hand spin the compressor clutch 15-20 times after filling the system. It also clearly states to NOT fill the system with the engine running.
The interior still needs to be put back together. I removed the shifter and linkage so I could lay there and apply the sound deadener to the firewall. I had planned to leave the glovebox out in case there was some electrical glitch.
A local friend is supposed to help with the evacuation and possibly also the charge of refrigerant.
Very Interesting. Thanks for the updates.
