64plymouth
I started selling them in the auto parts store in1985. I never had a problem with them.1980's? Just a guess, never tried using them myself.
Which intake are you running?I appreciate all the replies. I dry fit the intake and it fit ok. Fit ok with just the valley pan. Was hard to get on with one set of gaskets and valley pan, impossible with both sets of gaskets and valley pan. I guess I will order a new valley pan and start over.
While I’m asking stupid questions, the current valley pan I have doesn’t completely block the crossover passage (see pic). Is that a issue?
Great post. Once in a blue moon we used a paper gasket on one side to compensate for uneven tolerances.I've always used just the valley pan. The factory intended it that way. Never found a paper gasket under a factory installed manifold.
Now when building my latest 440 I used an older two four bll cast iron manifold. After running the engine for around 500 miles I noticed a spot/stain under the manifold, on the valley pan. I cleaned it off and drove it again. The stain reappeared. It was actually gas leaking when the rear carb was dripping internally after shutdown. (Had a higher than wanted fuel pressure issue)
So I'm thinking the manifold/head mating surfaces may not be perfectly square. I pulled the manifold, cleaned everything up and set the manifold onto the heads without any gasket or valley pan. The manifold had no gap at the top but did have a slight gap under it at the bottom edge. Not a perfect fit so I used one paper gasket between the manifold and valley pan. Haven't seen any stain since. (I did fix the fuel pressure problem)
You need to check the fitment of the manifold dry and without any gasket/valley pan first just to be sure. Useing 50 year old parts you never know. Maybe the heads were resurfaced, maybe the block was at one time. Maybe the aftermarket heads or manifolds aren't perfect. This is why they're throwing in the paper gaskets.
I use Indian Head around the ports and Ultra Black in the corners and on the front and back rails. Permatex #2 on the bolt threads to keep any oil from wicking up.
