Intake Manifold
71newp
3:25 PM
USA
Sorry if this question is too basic, but...
I want to change my 1976 360 2-bbl to a four barrel. The manifolds I've seen are either for the 318-only or non-egr. What do I give up by getting rid of the egr? The cars here do not get smog-tested. I'm thinking of using an Edelbrock Performer-type. Thanks,
Tim
Ok, sorry...I was a little mixed-up. Edelbrock does sell an EGR intake, but it is non-pollution control. Does this mean some things can't be hooked up/attached?
Thanks
You would want to plug all the extra garbage they had on those except for vacuum lines to operate controls and vacuum advance. Don't need EGR, they run better w/o
The Edelbrock Performer is a great replacement for a 2bbl intake, as is the Weiand Action Plus.
I agree with minnesota guy.... now would be a really good time to clean up the engine bay.
Generally, intakes that are specifically for 318's have smaller ports however, they will usually work well for a mild 360 and since the 318 intake ports are a bit smaller than the opening in the head, you won't have much of a problem with the flow going into a larger hole vs having an intake port that's larger than the head opening. The air/fuel mix doesn't mind going down off a step so to speak as much has it hates having to go up and over a step but port matching would give a smoother transition in both worlds and would be better.
I changed mine over to a Mopar Performance dual plane one. Really cleaned up the look of the engine. The only problem I had was the manifold had provision for the auto choke which I don't have cause I swapped over to a street avenger carb. so I had to put a 1" spacer in between. With the Mopar performance air cleaner their is just barely enough room for everything to fit. I actually had one of the ribs on the air cleaner rub the top part if the hood. I took it off and milled it down just a bit. You can't even tell.
