65coronet440
Hey everyone, I was hoping some of you could help me with this..
I have a 65 coronet 440 4dr, with a 440RB, 727, 8 3/4. recently I have been noticing a large fluctuation in my oil pressure. My normal oil pressure is around 65psi, but recently have been noticing that it will jump to 80-85psi while driving and will drop to 30-35 when at a idle, I should also mention that unless I two foot the brake and the gas to keep rpms up at a stop light it will completely fall and want to stall... now this doesn't happen all the time either.
I first noticed this problem after I put on a one wire 140 amp power master alternator and new belts. I was on a long road trip for a car show cruising at 60 mph at 3000rpms. ( I have 410 gears) when the oil pressure jumped up to 85 and then wanted to stall at a stoplight with oil pressure dropping to 20-25psi in this instance..
where should I start...?
thanks
thanks
