MoparR/T
a nice way of saying, it's NOT a #'s matching drivetrain?
I thought he was asking what the term meant, or is usually used for. The (insert you choice of engine here) part didn't click right away.doesn't even have to be aftermarket. block is from same time period, but, correct, not original to car.
1967 Dodge Coronet R/T - 440/375hp MagnumNo. What size/year is the engine?
That's assuming it's an original engine. If it's the original engine from 67 it should read C440-*** with the last three numbers being the month/day it was cast (for example, 721 would be July 21, 1967).that's a 67 440 HP ......... no numbers to match in 67.......the 6 is part of the assembly date, either the month or day, there should be another number with it....... if that date is just prior to the build date of the car, no one can say it's not original......... would match GTX R/T or 440 charger
I think you both are trying to say the same thing. There were no VIN stampings on motor/tranny in 67 so you have no way of claiming #s matching. The stamping on his pad shows C 440 and what looks like HP. That makes it a 67 440 HP block which is correct for a Coronet R/T. The other number (6) should have another stamp beside it to determine build date. The casting date on the block itself carries less weight than the stamped scheduled assembly date.That's assuming it's an original engine. If it's the original engine from 67 it should read C440-*** with the last three numbers being the month/day it was cast (for example, 721 would be July 21, 1967).
