I second the suggestion, add a coolant dye and take a look with a black light , if you don't see the tracer it's internalI would try some uv coolant dye and black light to look for possible leaks.
The later 8 bolt Vortec intakes used a plastic gasket with a rubber seal in the center. The plastic deteriorates, and will pump water into an end cylinder (1,7,2,8) when it sits, and hydro locks the cylinder. A better replacement gasket to use is the Fel-Pro 1255 High Performance gasket. It has the canted intake ports, dual pattern bolt holes (8 & 12), and is a composite material that wont deteriorate.I had a 5.7 chevy powered Express van. The van ran great but would lose coolant. No leaks, no drips. It actually boggled my mind until I went to work one night at a Kroger. It ran and drove fine to the place. I went out to start it the next morning to go home and it would turn about a quarter turn and stop. I was like wtf, turns out it had a small head gasket leak into the cylinder. But while driving it there were no signs of a typical head gasket problem. Clean oil no steam out of the exhaust nothing that would indicate a head gasket. But over night I guess the pressure that the system had it in when parked would push the coolant into a cylinder and hydrolock that cylinder. I would have to try and turn it over like 15 times to get it to squeeze out the coolant. Then it would finally run.
My 2007 Ram 1500 has 366,000 miles and still runs great. It uses oil and isn't quite as peppy as it once was but it is still going.
Last year I replaced the radiator because I spotted some crystallized coolant on some of the tubes at the edge of the tanks.
Since then, I still have to add water to the radiator. It doesn't leak when it is running. There is no steam coming from the exhaust pipes. I do notice some wetness under the truck in the morning, no more than a couple of ounces and not every day.
K Seal.
The next step in not leaving meat on the bone, is walking. It's time for a new engine. The parking lot at work was full of hemi trucks, hundreds. I have never known anyone that got that many miles out of one. The highest I've heard of was around 300 thousand. My guess is that It's burning off the engine when hot and when cold, then going to the ground. Head gasket.No, I have not. I don't have one and have just been nursing this engine.
I know it is long in the tooth. I hate to pull it when it still runs fine. It is not in my nature to leave much meat on the bone.
At 366k you're going to have other things start to go, differential etc
At 366k you either dump it for new or rebuild the engine
2 cans
You're a regular ray of sunshine.
I don't think the cap is bad. I have let it sit overnight and removed the cap to add water and it was still under pressure when I turned the cap.Pesky radiator cap is slowly venting overboard when it shouldn't?
@Kern Dog
Ok, under pressure, but at what pressure? It may be relieving pressure at a lower operating pressure than intended by design.I don't think the cap is bad. I have let it sit overnight and removed the cap to add water and it was still under pressure when I turned the cap.
