Looking For Some Head...
khryslerkid
9:44 AM
Hanover, Pennslyvania
gasket information.
I'm researching head gaskets with a 4.410 bore.
The smallest compressed thickness in a composition is .039, that gets me 9.34:1 cr
I can get a cometic @ .030 that gets me 9.5:1 cr (where I would like to be for the cam I'm useing) but they are $85.00 each.
I can not find the right, shim type gasket, with a 4.410 bore.
I like the idea of the composition gasket. Would the difference in compression be that much to notice when the cam recommends 9.5:1 cr?
you'd never know the compression difference; especially after some carbon build up. if you want composition gaskets i'd just get some cheapo fel-pro 8519's. i've never had an issue with them and they won't hang over in the bore like 1009's.
If I order the 1009 felpro with a 4.410 bore, will they be "hanging in the bore"?
Mopar Preformance offers two gaskets for $62.00 and are suppose to be the felpro 1009.
I don't see the 8519 with bore choices. I'm .040 over
Man, you've got to re-think your title here....next thing Richard Cranium will be climbing into you. :rolling::rolling:
i just measured an 8519 and it was 4.51". avoid the 1009's like the plague, unless you have a 4.25 or smaller bore. the 8519's are pretty common. the mopar .020" steel shims will work at .040" but need a fairly smooth finish on the heads and block.
Thanks Lew, for taking the time to measure one for me.
Hey, it's all about getting your thread noticed!
Well, you got my attention at 5:30am :rolling::rolling::rolling:
