R/T
440 auto 22" stock copper 3 row with clutch, never boil, no pressure needed, use Evans waterless coolant. Works great in traffic. Last forever , no corrosion. Jay Leno puts it in all his cars.
This might be a dumb question, but which OEM style fan would fit and be adequate for my car? Ive seen so many different part numbers for mopar fans and I really dont know what the difference is.With that 3 core radiator if your running 180 - 190 on the road when its hot out I think a fan swap to a oem style clutch or 7 blade fixed plus adding a shroud should cool it down at slow speed and idle. Make sure your hood to rad support seal is good and back of hood to cowl seal also.
make sure you have a good 180 thermostat.
Also do not waste your $ on one of those chrome universal shrouds use a oem style do some measuring and hit the web sights or swap meets.
I need some help with my cooling system. Im looking for a 22" radiator that will cool the 440 in my 65 coronet. I currently have a 7 blade flex fan and a 3 row summit aluminum rad that just isnt cutting it at idle or slow speeds. Im looking to switch to a stock style clutch fan and shroud and a better radiator. Ive done alot of searching, but most of the radiator suppliers list their products as fitting 66 and up cars. Is there a reason that some of these radiators wont fit a 65? Some of the brands im looking at are OER, Griffin & Wizard.
2843225 is a fixed seven blade , not sure on the clutch fan part numbers,This might be a dumb question, but which OEM style fan would fit and be adequate for my car? Ive seen so many different part numbers for mopar fans and I really dont know what the difference is.
Problem stil not resolved. Just been busy and havent had time to work on it for awhile. The rest of the cooling system is working fine. It has a new robert shaw t stat and a high flow water pump and housing.maybe on the late show here if problem was resolved. but ... is the cooling system all mechanically sound? T-stat and radiator working properly? any cold spots on the radiator? 2 cents.
Ok what exactly do you have here? Which radiator are you using? I just finished replacing the radiator in my 68 coronet...also using the Hayden 2947 fan clutch, factory 7 blade fan and factory shroud....went from an aluminum ECP radiator to a different 2 row 1.25"tube aluminum radiator from a guy off ebay....fitment in great, decent gap between radiator and face of clutch....lower hose not interfering with oil filter.....Just got back to working on the car again and need some advice on which radiator to buy. I recently purchased a 216 fan and a low profile hayden clutch, but cant install them because the clutch is touching the aluminum raditor. I temporarily installed my original 2 core factory radiator for the old 318 in the car just to check for clearance, and the clutch and fan fit fine. I can't test it out, because the radiator outlet hose will hit the oil filter. Upon closer inspection, I noticed that the original radiator is angled to match the tilt and offset of the engine whereas the aftermarket Summit radiator is mounted flat. Where can I find an original or a good reproduction big black radiator?
Im using a summit brand 3 row aluminum radiator and a flex fan currently. I have a 7 blade 18.5" factory fan and a hayden 2947 clutch that I tried to install, but the summit rad was too wide.Ok what exactly do you have here? Which radiator are you using? I just finished replacing the radiator in my 68 coronet...also using the Hayden 2947 fan clutch, factory 7 blade fan and factory shroud....went from an aluminum ECP radiator to a different 2 row 1.25"tube aluminum radiator from a guy off ebay....fitment in great, decent gap between radiator and face of clutch....lower hose not interfering with oil filter.....
I have this radiator, 26" and black...
https://www.ebay.com/itm/1966-1972-...-/303574254985?_trksid=p2349624.m46890.l49286
It might come to that. Hate to spend that much on a radiator but im gettin tired of this problem.Call Bob at Glen-ray, He'll set you up...
I recommend you sell that 3 row and use a 2 row. You'll get your clearance back and probably cool better... you don't need a $1k+ radiator, unless you have a documented 6 figure car!Im using a summit brand 3 row aluminum radiator and a flex fan currently. I have a 7 blade 18.5" factory fan and a hayden 2947 clutch that I tried to install, but the summit rad was too wide.
Thanks, that info really helps. Im looking into that same radiator. Can you tell me how thick it is at the core? It doesnt show that dimension on their website. Also, what temp does it run in idle?I'm running this "hodge podge" of parts that's keeping a Hemi in check, in a '65 Coronet,
ECP 22" radiator https://speedcooling.com/22-Mopar-BIG-BLOCK-HD-Aluminum-Radiator.html
Dominator DOM-545 Cooling Fan Shroud, 22 x 19 x 3 Inch
Heavy duty Hayden 2947 clutch, 2765 didn't move enough "wind"
18.5" fan
Flowkooler pump
Milodon 180 stat
I do have a pusher fan, but I really don't need it, but makes you feel better knowing it's there.
Also, it's a stick, no tranny cooler
From flange to flange is 2.75" with the core slightly narrower.Thanks, that info really helps. Im looking into that same radiator. Can you tell me how thick it is at the core? It doesnt show that dimension on their website. Also, what temp does it run in idle?
Here's my setup...
What radiator are you using?
