Charlie Brown
- 7:15 PM
- May 23, 2021
- Vars, Ontario, Canada
Current engine is a 426 street wedge with a Lunati 10230703 cam. Car / engine runs strong from idle to 6200 rpm. Currently running a Torqueflite auto, reworked factory convertor to give approx 2400 stall. 3.23 rear gears and 28 inch rear tires. Cam specs as follows as taken from the Lunati web site:
Hydraulic Flat Tappet. This high performance street cam likes 2400 RPM stall, 800 CFM carb, dual plane intake and headers. Makes un- equaled power to 6200 RPM with proper valve springs.; Advertised Duration (Int/Exh): 268/276; Duration @ .050 (Int/Exh): 226/234; Gross Valve Lift (Int/Exh): .494/.513; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1800-6200
There's a strong probability that I'm going to switch out the auto trans for a Tremec TKX and a rear gear change (3.55 or?) - yet to be determined.
My question is, will this cam perform the same behind the Tremec as it performs behind my auto trans. Most of my research shows that this cam is being used behind auto trans cars. Opinions please.
