Well, here it is... 1011HP@7000rpm 801TQ@6000rpm Now I just gotta get the power laid down to the track properly.
Torque peak at 6000 Horsepower peak at 7000 801-TQ/1011-HP Heads must flow massive amounts of CFM. How wide a RPM range is the fattest part of the torque band? Thanks for sharing the results Mike!
If all goes well and you get it dialed in. You're looking at a 8.80 to 8.9x hot rod. And you will be right around 150mph. It's going to take some time to get it all sorted out. 8 second rides aren't easy to get 1st time out. I suspect 9.0x to 9 teens for a few outings.
Mike after you get comfortable in the car. Make steady passes, I'd get some Q16 race gas if California allows it. Jet up 8 jet sizes and hang on.
We do have Q16 sold by the Fuel Vendor at my home track in Famoso (Bakersfield) and a few of my buddies run it and they like it. They are there every race with a truck full of different brands and grades of race gas, plus methanol (alky). My good friend just finished his 540 aluminum Block Hemi and he has it set up with old school Hilborn Fuel Injection running Alcohol. He has yet to run it but it made right at 1000 on the dyno.
Q16 is forgiving and you'll make about 30hp more than c12. But you will need to jet up quite a bit so you dont go lean. For a car of this caliber. A datalogger is must.
