Maybe for the "pure restorations" but you can always keep it for a later date. Honestly as a driver you could clean it up and paint it, would look good in there i think! Just sayin...
Alright . . . so I'm in the process of cleaning up the engine compartment - I'm shooting for the clean look under the hood. So I'm removing all the pieces and parts that can be removed and welding up the holes.
Including this part that says " do not remove " . . . ruh roh . . .
So, the certicard holder is in the engine compartment - but nothing in it . . .
I assume it's "important" for pure restorations - but if I'm aiming for a driver, then suggestions ? ? ?
Is it strange that my holder either never existed or was long gone? It was a one owner car too, I have to original title they received after paying off the loan.
Your doing a great job, that is the way to strip her, looks good and doing it this smooth the paint should be as shiny as it gets!
I see elsewhere you mentioned Led Zeppelin, Here is a tribute to him by another group that is tops to me, You'll see Led in the balcony.. enjoy.
[video=youtube;6D2DohKUhZw]http://www.youtube.com/watch?v=6D2DohKUhZw[/video]
Still got some corners that I can't get the paint removed, so I picked up a little hand held spot media blaster unit to see if that'll help me get the last little bits cleaned up on the fender. Gonna check and see how it does on little bigger areas too. Curious to see how it works - wish I had a rotisserie ! ! !
You have more patients then I do! I just kept the original paint and sanded things smooth. I don't know if I would have had enough patients to sit there and sand all the paint off...
I do use my sand blaster for parts and I used it on the outside of the inner fender, worked absolutely fantasitic. Does make a royal mess though.
I've used the self etching primers with luck before but it doesn't seam to protect the metal from rust like Epoxy if not topped soon. As far as paint questions go I got sick of getting misleading answers from the paint salesmen and started going on the paint manufactures sites and looking things up for myself "lots of info". They'll usually tell you what the product is intended to be used for and how to prep before application "no guess work or misleading answers". That's some tedious work your doing, ever thought about paint stripper? If seeing the time and effort your putting into just cleaning it is an indication of how you will attack the whole restoration then I think it will turn out great. Good luck
