Engine mock up…
Thank you for your comments…. I’m covered!The engine looks great.
Be aware that it will not clear a stock hood. I don't recall if you have an aftermarket scoop or not but the RB block in a Charger with even an Edelbrock RPM intake and 4 barrel requires a deep drop base air cleaner.
Single plane intakes like your Torker 2 and the Victor do sit at least 3/4" taller.
I'm not trying to piss on your efforts, I just thought I'd let you know.
Just a little tight in that garage.Finally was able to get the stripe installed on the car. It Took me two tries. 1 to 10 I think it’s about an 8.
Now it’s done…Installed the windshield today. One more thing off my to do list. Getting closer to first drive day!!View attachment 1679905View attachment 1679906View attachment 1679907View attachment 1679908
I installed my Sixpack scoop from underneath the hood rather than mounting it on top of the hood.Thank you for your comments…. I’m covered!
The Aces ignition failed right out of the box.Installing the ace‘s ignition system, and tach signal booster. Not much room to mount this stuff, had to make brackets. Ignition and relays for fan controllers under battery tray, fan controller panel and tach meter booster signal module mounted on driver side next to the battery. Hope to have the car running in two weeks.View attachment 1839220View attachment 1839221
