Well I would like to get this thread going again! It was a great summer, but it didn't include much shop time. I have spent a great deal of time slowly tearing down this motor and have a much better idea of the inner workings. I have come up with a plan that I would like to run by all of you for opinions. The recipe is as follows:
440 Source 512 stroker kit
Bore 4.36
Stroke 4.250
Piston 27cc dish (1.485 compression height)
Rods 7.100
Comp Cams Hydraulic Roller Retrofit .549/.544 lift and 242 intake and 248 exhaust @.050
Edelbrock Performer RPM Intake
Trick Flow 240 heads 78cc
I would like to see a 10.5 : 1 compression ratio.
The car is an automatic with a 2000 stall and 3.55 gear ratio. I am not opposed to changing either of these.
I have calculated the deck height by measuring the diameter of the crankshaft bore then dividing in half, then using a 12 inch caliper from the deck to the crankshaft bore.
Deck height as it sits 10.742.
With the above parts: rod + 1/2 stroke + comp height + .018 in the hole = 10.720. Is this correct? Seems like a lot to mill off the deck.
Using the Summit racing compression calculator I came up with about 9.9 :1. Not quite where I want to be. This is with an .039 gasket.
Give me your thoughts and suggestions. Try to be gentle, my head hurts from all the math!!
Bore 4.36
Stroke 4.250
Rods 7.100
