Sometimes our perception of time can be skewed. At 60 mph a mile takes a minute, 30 mph, 2 minutes. What were the circumstances? Wide open throttle and a hard pull? Cruising along at 50 mph?
If it weren't for the noise my first suspect would be a stuck by-pass if it was in fact 10 seconds. But that only happens when the pressure exceeds relief pressure and opens the valve. Usually an ice cold engine revved up.
Broken cranks are rare, but this has the symptoms. Gently rock the crank from one end, feeling for a bit of free movement (it will be small) and watch the other end.
Once you pull the pan you are relying on visual inspections. Always a good idea to have a good idea of what you're looking for before you do that. Try to isolate the area of the noise. Pull the plug wires one at a time and see if removing the load from any one cyl changes the noise.
