Oil pump leaking
aaron4915
1:59 PM
Kansas City
Hello everyone! I’ve had some oil constantly on my oil pump and I can’t figure out where it’s coming from.my oil pressure is great. I added dye but still can’t trace it? My question before I pull the pump off and replace the gasket should the check valve bolt be torqued a specific spec? I feel like it’s heaviest around that bolt? Thanks for any help!
Plug on bottom of pump and faces rear of car. Make sure it's not the filter.
Ok thank you! I’ll check it first
i've had the pump cover seep before. check to make sure its flat. the one i had was warped.
