Points or no points? That is the question.
I've been running Standard Blue streak points/condenser for 18 years and many miles, preventively swapped them out every year.
Had one bad condenser last year, was bad out of the box.
The car was still driveable but had random misfires at idle, cruise and acceleration.
I've also had a set of new points that had corrosion on the metal spring which caused a misfire.
Other than that no problems.
Try Ray Brenner @ Halifaxhops@hotmail.com. Good Guy and knows his ****. Delt with him many times for points systems. Stocks everything.
I think that far more forum members have been helped by Nacho than any blowhard from Decatur.
If the forum still had the red X, it would be immediately evident who is liked and trusted and who is not.
This guy have no idea that I was Don’s customer buying one of the maybe last A688 units, which failed and had to get the warranty (money return) while the first HR688 came out and the ppl who got it found the HEI unit hidden down the case… being talked around 12 years ago on several boards.
Don itself told me about the problem to keep the A688 unit being built on an email and the reason to move on into the newer units, which I maybe still have around in my email inbox
Different internals… well, Halifaxhops already shown the internals difference pics between the HR688 and the HRR688 units, which at the time when the HRR688 was released wasn’t published and ppl was scared about being “scammed” again ( Halifaxhops himself as he let us know on #24 reply in fact) , so, no need to talk more about.
Is just about keep the unsense war around
Nacho, I have not always agreed with you on everything but you sure do try to help people. We all benefit from that. I don't see you being rude to others or bragging about how smart that you are. I appreciate your input and hope that you don't let a few mean people chase you away.
I was curious and called FBO yesterday. Here we go. Don built around 15 units with the HEI and stopped them according to Dana. The new ones are totally different no transistor to overheat either. as many made in USA electronics used as possible. Case and board made in the USA. Assembled and programmed here also. Explains alot of the price to me. I would run one for sure.
I've been using a RevNator for over a decade and have moved it between multiple Mopars. I've really liked it, I also would love to use an FBO box Don is about 30 min away from me in Cottage Grove. I had Halifax set up my fire core distributor it's been awesome. I drive my Belvedere quite a bit, nearly daily driven.
If no transistor ,what switches the coil current on/off? Post #64.
I got the 00020 unit… probably the first one sold/being used overseas. My car is on the customers ride of their website. Unfortunately my car is dissambled since 2013. Still need to get back to Venezuela to finish some of the body job and reassembly it.
The 2 years my car was in one piece with the Rev-N-Nator box I was really happy, not as hot like the Chromed MP or the A688 box (specially when starting), but more stable along the RPMs response without miss a beat, like I could feel with the others.
i have been running a brand X HEI thingy on my ram charger for years. made a bracket and put it next to the booster. had to rig something when the orange box went a way plowing snow and just happened to have one in my tool box.
My car is a pretty much daily driver, not a weekend warrior or show queen, not that is a problem, just I probably put more miles on my car then most people, so I might have a bit more practical experience on todays parts, not the good ol days when you can buy good parts at the parts stores:
. I use factory mopar electronic ignition on my mild 440, starts up easy no matter the weather, revs up to 6k with no breaking up, great system. Not hating against hei or any of the other aftermarket systems, just saying factory can be cheap to get and still works. I’ve also ran a dual point distributor for a while, it works, but there is a noticeable difference, doesn’t start as easy, doesn’t seem to rev as good, still works good enough though.
With that being said, I’ve never tried any of the aftermarket high dollar stuff, but I’m sure it works too until it doesn’t, until it doesn’t. But I’ve had my points distributor fail, and I’ve had my electronic ignition fail. No system is bomb proof, they will all fail! But the benefit of a more factory system is parts are a little easier to get.
So in my experience, I would prefer the factory electronic ignition. I still have a little carb tuning to do, but I’ve get good fuel economy, it’ll out run a newer Camaro, and it just works. Just throwing my 2 cents in the piggy bank.
What coil are you using? The Standard that has been good for two years leaked it's oil. What ECU do you have?
Matching the ECU, coil resistance and ballast resistance are all important. @HALIFAXHOPS gave me those specs but I'll be darned if I can find my notes. May be he will be gracious enough to repeat them. I could post them in a sticky so we can find them easier.
I am sure there are more.
OK the coil should have a primary resistance of 1.5 ohms for a mopar standard ecu. Not a big fan of the new Mancini boxes they are Chinese knockoffs painted orange and have a fake transistor. They have a pretty good fail rate also.
PXL_20250723_214207701.MP.jpgPXL_20250723_213757778.jpgPXL_20250723_213643995.jpgPXL_20250723_213444552.jpgPXL_20250723_213441350.jpgThanks for the charts. From your chart it looks like my ballast resistor is the wrong size, 25ohm. And the NGK coil primary measures 2.4ohm than meter slowly drops to 1.9ohm. Secondary measurement 10,850ohm. This car is a cruiser not a racer.
[/URL]
In the pic of the bal res, it looks like 0.25 ohm, not 25 ohm. 0.25 ohm bal res with a 2 ohm coil would be an odd pairing.
That ohm ballast is Race only. It will fry the ecu which is a knockoff if you did not know hence the word "replaces" on the label. Common. Prob Mopar Authorized which means they bought the right to slap Mopar on it! Coil is high also.
Did find that orange ECU with that sticker in picture on Jegs website. I did not know it was a knockoff. Shame on Ma MOPAR for letting them use the MOPAR label.
There is a ton of it out there now.
