ron
I've been following you and your brothers cars for a long time hoping to see you at one of the tracks to say hello
very very nice 63
I hope to make it to Cecil in late Sept or some time in Oct. I plan to make a Saturday test & tune. I will try to remember to let you know as I would love to meet you and see that sweet 63 up close. Ron
I'm hoping that after the upcoming changes I'll be able to post my findings here. Tell me what you think of the combo:
70 Charger 4100 lbs with driver.
493, 10.7 compression. Iron block, Edelbrock RPM heads Unmodified. 261/271 @ .050 .558/.578 Lunati Solid, 850 Demon carb, Edelbrock RPM intake, 2" TTI headers, 2 1/2" exhaust & tailpipes. MP electronic ignition, Chrome box, MSD blaster 2 coil. 727 with 3000 stall, GV OD, 3.91 diff. I have access to slicks but may buy some Drag radials for racing.
Is this capable of breaking into the 11 second bracket?
Yes that should run easy 11's. Actually my combo is not all that much different. I use a solid flat tappet thats .584 and .592 lift with 264 & 270 @ .050. But I use 1.6 rockers for .624 and .632 lift. Indy EZ heads with light port work and 10.6 comp as it runs on 92 pump and has good quench. I also use TTI 2" headers and a full 3" exh with X-pipe. I run the Indy dual plane intake and a 850 DP. I also use the MP ign as I am running the orange box. Mine weighs 3700 lbs so you are carrying about 400 more lbs but your combo should still go easy 11's and maybe even lower 11's. Good luck and keep us posted on how it goes. Ron
