diesel_lv
Yes, Fitech EFI.I just noticed you posted today on this @diesel_lv, was about to ask you how it was working out. You run FiTech EFI correct?
Yes, Fitech EFI.
Pretty much any stand alone distributor works w Fitech. All Fitech needs from the distributor to run is the tach signal. When you get the signal from a coil, there can be noise/interference, which the dedicated tach line, similar to what MSD and HEI distributors have.I'm running my 600HP unit (30002) with a MSD type distributor and 6A orange box (no timing control), and just wondered how easy the install went for you? I see the Progression Chrysler BB unit is not HEI style but small cap dizzy, so what changed in the wiring to make that work with FiTech?
This is what mine is currently set up like. Not sure if your setup was the same, but just curious. Any info appreciated as I may consider this purchase in the future, when they are in stock again.
I have had email and phone conversations with the owner/engineer at Progression Ignition, the latest "round" starting around the end of December 2021.Last I heard out of stock until July.
Bio- if for some reason it doesn’t fit with the 6 pak, you have a buyer!I have had email and phone conversations with the owner/engineer at Progression Ignition, the latest "round" starting around the end of December 2021.
I've posted my over the top enthusiasm for this product, and I'm absolutely going to get one as soon as they are available.
Progression has had some parts/materials supply chain issues like everyone basically, but I can absolutely assure anyone who is interested in these, they will be pleased with the new batch of Mopar distributors! I don't think anyone will have any clearance issues with the new units fitting big blocks, even with fabricated aluminum or "oversized" valve covers or aftermarket aluminum cylinder heads.
I'm certainly taking advantage of its features in the 572 I'm having built, but I am definitely going to install it in the 440 6bbl I have now.
The new units once they're available, should present ZERO clearance issues for any Mopar engine!What heads are you running , and any interference with the heads themselves ? I tried the Pertronix distributor with the Edelbrock E Street heads and was a no go
Reality I probably won’t be done by July with mine as well. Suspension just starting to ship now from a January order..
Good luck with the suspension and any other new parts you need. I got all of that and more squared away and installed in 2020.
Just got an email from Ted about 5 mins ago and now it's looking like delayed until the end of August.Last I heard out of stock until July.
Yeah, he is having problems with the supply chain like so many are.Just got an email from Ted about 5 mins ago and now it's looking like delayed until the end of August.![]()
Please post feedback here!just ordered mine!
The one in my Charger is four years old now and the one in the Buick is at least five and not a lick of trouble with either one.Any long term user reviews?
Im looking to buy one of these and would like feedback from long term users.
It's the greatest amount of control and feedback data that can be had without going to an EFI type system computer.Any long term user reviews?
