Question about this hydraulic roller cam …is it billet steel or not ??
Moparjack 489
5:06 PM
Germany /
Hello, anyone knows sure what the cams are :
Howards Cams Retrofit Hydraulic Roller Camshafts 723445-08​
Billet steel or don’t ?
If, IF! the pic is accurate, or even of the referenced cam.... it looks billet. I would call Howard's tech line, and ask.
Oops! In small print in the add it SAYS it's not the actual cam, so reiterated, call Howard's.
2nd edit: the pic is a Chevy cam.
Email howards with the serial # on the camcard, i just did this the other day and they got back to me in a few hours.
It is a billet cam so you are correct with the bronze parts!
So it’s a billet cam
I was going to go melonized myself, then read on hughes page for it that it shouldn't be used with a HV pump... not sure why though... i need to order a shaft myself soon
HV pumps put more load on the gear.....how much I don't know but the pump body is larger than a regular volume pump by about 20%
Wouldn't that apply to bronze gears? I'd be watching gear wear on either.
Yeah, i kinda figure they have the disclaimer on there cause morons like me use a HV pump and don't really need it.. i'm just gonna make the pump work less by running 15w oil :) Problem solved!
yea, it’s billet .
Melonized gears I may have not good experience, because the manufactor always say don’t use high volume / high pressure oil pumps , and only use it on new camshaft ‚s. So the change from a bronze gear to a Melonized one on the „ old „ camshaft can be able to run in problems too … with the bronze I still have better feeling ….
