what is it your trying to do ?? what kind size & type of Blower a Centrifugal or Roots or Screw type blower ?? how much boost ?? what kind of drive system ?? I've ran a bunch of Blower Combos, never a EFI but did run mech. FI allot, Carbs & linkages are pretty easy... recommendations will be based on what you expect & what your ultimate goal is, how it will be used ??, do you want it bullet proof & to last ?? what kind of budget do you have ?? they aren't cheap, you can't skimp & expect them to last, what kind of knowledge base do you have ?? what kind of tools or access to them do you have ??... camshafts/valve-train, heads, deck & head surfaces O-rings & head gaskets, rods, bearing, pistons - especially materials/compression style/shape of the piston design, type of rings, what type cooling system & drive {blower engines can produce allot of heat}, induction system, fuel systems, pupms reg.s etc., ignition systems wires & coil, are all basically boost specific... your drivetrain will need to be beefed up too for the added HP/TQ that it will endure after a Blower too... the bottom end must be bullet proof, if you plan on running any real boost & it lasting any period of time... I would highly suggest you by some books on Blowers & the type of system your thinking of using, Boost & it's effects & how or what &/or why you need to do certain things... There are books out there do a Google search for books about Blowers or How to Build a Blower Engine... good luck
