D
Deleted member 214
Guest
70 Runner 440+6. Dash ammeter bypassed long ago. Voltmeter used to jiggle and wiggle, 13v when revving, dropping below 12 with lights on, would even wiggle at idle in time with the turn signals. Got car back from shop with newly rebuilt motor last Thursday. Voltmeter seemed stuck on 12 so I thought it was just a bad wire. Drove it a few times since, runs great. It seemed to have a hot start problem, though, but was easy to crank when cool.
Tonight I tried to start the car after sitting a day. It turned over twice, then starter solenoid would only click.
Battery read 12.2v. Put a charger on it, car started up and ran fine. However, using a meter across the battery, it was 12.26 volts with all accessories off and engine above 2k RPM. Turned on headlights, dropped to 12.10 volts. Cheap volt meter under dash read just under 12, then moved slightly to 11.5 or so with lights on. I replaced voltage regulator, no change. Checked to make sure the blue and green wire on the alternator were in the right places, and they were. Engine is grounded to the firewall. Battery ground is bolted to the engine - used to be bolted to the head, but with the Edelbrocks the shop bolted it to the block near the motor mounts (can't see in the dark garage). No idea what to try next. Looks like my trip to Carlisle will be riding in my brother's Avenger, dammit! :angryfire:
Any hints as to what to try when I get home?????
